wxd4000's avatar
wxd4000
RBK753 DNS Setting greyed out
Hi, I have a Orbi RBK753 mesh wifi system, I recently noticed the DNS setting is greyed out, and I am no longer able to use my NAS as my DNS server. I have tried to reboot the router and disable the parent control, but neither helps. The firmware version is V4.6.5.14_2.0.54. Is there anything I can do?
  • FURRYe38's avatar
    Be sure Armor or Smart Parental Controls are not enabled.
    Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
  • plemans's avatar
    Are you running it in access point mode?
    Got a screensnip?
    Are you using armor?
    • wxd4000's avatar
      wxd4000
      Thank you for your reply!
      It is not in AP mode. Armor and parental control are disabled. Screen shot is attached. You can see the DNS setup is grey-out, the router MAC address is also not able to be changed
      • plemans's avatar
        have you tried a factory reset?
