Wim2019's avatar
Wim2019
RBK753 with extra RBS750, satellites led goes every 20 minutes to white and blue. Why?
I bought a Orbi RBK753 set in begin 2022. I had no problems till I changed this year from internet provider. The RBK730 has to be installed as access point (AP). I bought also a new RBS750 to joint the RBK753.
After those changes, All the Satellites goes burning about every 20 minutes the white leds for 1-2 minutes and after that the blue led for 1-2 minutes.
All the RBK753 and new satellites has V7.2.6.31.
If I put down 1 satellite, then this problem of lighting up white and blue is gone.
Is there a solution if I like to use all satellites in AP?
Thanks Wim
  • FURRYe38's avatar
    Does turning OFF the other RBS and leavin the new RBS ON do same thing?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
