KBDMB1
Mar 21, 2022Aspirant
RBK852 - Slow download speeds with NZB's - QoS issue?
Hi There,
I have been loving our Orbi RBK852 setup at home, great coverage and ease of use but I have been noticing some slow download speeds when using NZB files to download various types of files. I don't see this issue when using for example other means of filed download or direct download in the browser.
When doing a speed test, It always reaches the max speeds for download and upload(d:600Mbps u:40Mbps), both wired and through WIFI. But when using my desktop, wired connection and NZBget to download items, the speed hang at around 25MB/s and stay there.
To me it looks like the Orbi systems is throttling the desktop speeds in favor of other devices, perhaps not recognizing the type of connection/download. However when using some other download client on the same desktop and same devices in the network, the tor-rent client is able to reach speeds of 60+MB/s.
I have tested different NZB files and tried messing around with some settings in NZBget and Netgear admin page. Nothing really changed anything, any help would be appreciated, thanks!
Model: RBR850 and RBS850
Firmware: v4.6.3.16
OS: Windows 11
Sqft: 1500
Just wanted to add the resolution to this topic, it seems that the slow download speeds were on my end. I recently switched to windows 11 and it did not cross my mind, so after doing some research and some tests, I reinstalled the lan drivers on my desktop and all of an sudden, the speeds were capped.
Thanks for the help and hints.
My guess is that the Orbi router is not aware of, nor has a mechanism to control NZB downloads.
Much more likely that the combination of NZB downloader and UseNet provider are "doing the best they can."
https://www.cogipas.com/nzb-downloader/
https://www.cogipas.com/best-usenet-provider/
If there is a way to increase NZB download speed, my guess is that it will be found in UseNet forums rather than here.
- KBDMB1Aspirant
The thing is that using the same usenet providers and nzb downloader with my pervious router caused no issues. I could easily reach almost the max speeds. I have of course also tried different providers and downloaders in combination with the Orbi and all have throttled speeds. To me, like you mentioned, it sounds like the Orbi is not detecting the high traffic created from the nzb downloaders as priority. So not sure how NZB or UseNet forums could help here.
Any other suggestions I could look at? I will in the mean time also stroll the NZB/UseNet forums.
Thanks
