Erte
Dec 07, 2019Follower
RBK852: buying two and using both satellites in one system
I am looking at buying Two RBK 852, each with a router and satellite. Could I then use both satellites with the router and use the remaining router elsewhere? This is a little pricey, but wondering if this will work using both satellites.
You should be able to do this.
If you were a little patient, satellites are supposed to be coming in the next few weeks. Someone asked that question during a live Q&A.
