IAP
Dec 14, 2020Aspirant
RBK852 connection issues
Hello and good day to you all. I recently purchase the ORBI mesh WiFi. I had the nighthawk before and it was working perfect but wanted to upgrade to get better speed. I have AT&T as my ISP with 1...
Mstrbig
Dec 15, 2020Master
IAPIAP wrote:
Hello and good day to you all. I recently purchase the ORBI mesh WiFi. I had the nighthawk before and it was working perfect but wanted to upgrade to get better speed. I have AT&T as my ISP with 1gig up and down. When I hooked up the ORBI there were no difference in the speed. Netgear technical and AT&T could not help me to get the Orbi working right. I would like to know if any of you know what the configutation should be on my AT&T modem, it's an Arris BGW210-700. I wanted to give it one more try before I return the Orbi. I want to believe the Orbi is much faster than my nighthawk.
Was your Orbi hooked up to your Arris BGW? If so what mode was it in? Also Internet speed is going to be determined by your ISP plan, and even if you get faster and stronger routers, wireless mesh systems, etc., your Internet speed will still be limited to your plan but your LAN network will be faster.
- FURRYe38Dec 15, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Switch Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
IAP
