IAP
Dec 14, 2020Aspirant
RBK852 connection issues
Hello and good day to you all. I recently purchase the ORBI mesh WiFi. I had the nighthawk before and it was working perfect but wanted to upgrade to get better speed. I have AT&T as my ISP with 1...
Dec 15, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Switch Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
IAP
