KOR-CAT
Nov 03, 2019Aspirant
rbk852, Orbi Satellite Model RBS850, spec true?????
http://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Official Netgear RBK852 PDF
140~141p
RBS850 spec
Radio data rates
2.4 GHz: Max 400 Mbps
5 GHz Front haul: Max 866 Mbps
5 GHz Back haul: Max 866 Mbps
What???
Or really?
I'm korean.
Google translate use.
Are you sure you read that correctly from the PDF file?
Radio data rates: Pg 139
2.4 GHz: Max 1200 Mbps
5 GHz Front haul: Max 2400 Mbps
5 GHz Back haul: Max 2400 Mbps
FURRYe38 wrote:Are you sure you read that correctly from the PDF file?
Pg 139 is RBR850, Pg 141 is RBS850. Both are correct on paper.
I wonder if Satellite is really that slow.
I see. I'll see if I can get some confirmation on this.
