espcar
May 27, 2026Star
RBK852 Unable to connect to admin web/app
A bit like the issue with the RBRE960, I now longer can connect to the admin ui of my RBR850 anymore, and the app doesn't seem to find it either. I suspect the issue started May 23rd, when I got a n...
CrimpOn
May 27, 2026Guru - Experienced User
espcar wrote:still able to log on to the admin web on the satelites
These are accessed using the satellites IP address, correct?
When attempting to access the router, what happens?
- The connection fails to connect with an error message about "cannot be found"?
- The connection connects, but is rejected by the router?
- The login window pops up, but the password is rejected?
espcar
May 27, 2026Star
The satelites are accessed by the IP address, yes.
The router gives "Connection refused" and no question about a password.
Opened the dev tools, the router gives no http status code back, as if the http service was not running, but faster than it would if the service was running, so kind of feels like firewall responding blocked instead of dropping the package.
