simultech2
Nov 18, 2021Aspirant
RBK852 unbearably slow
I have had an Orbi RBK852 for about 3 months in a larger house (ISP router doesn't reaching far enough), and its unbearably slow. I'm at a loss of what I can try, so looking for any ideas. Here is the speeds from my tests. I have Xfinity ISP, all speeds via speedtest.net.
Xfinity Router Ethernet - 900mbps
Xfinity Router Wifi - 600mbps
Orbi Ethernet - 200mbps
Orbi Wifi - 80mbsp
Orbi is plugged directly into Xfinity router, and my xfinity router ethernet test was done with the same cable/port plugged directly into a PC (so its not cable, port or anything on the xfinity side). Tried factory resetting twice, disabling the satellite and ensuring no other devices wired or wireless on the network. My theory is that its the orbi itself is just broken, given its ~25% of the speed and all wired up.
Any thoughts or ideas at all? Any help appreciated, I'm ready to throw it in the bin and buy something else.
(re-posting from https://community.netgear.com/t5/Orbi/RBK852-unbearably-slow/m-p/2164373#M128752 based on recommendation).
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?If your ISP modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
