mikepade's avatar
Nov 14, 2021
RBK853 - Satellites drop Internet connection
Hi all,
we have a RBK853 package and since initial installation we have the problem that the Internet connection is dropped multiple times during the day from all 2 satellites. Totally annoying when you have to work from home with stable WiFi. We have tried almost any possible channel settings and the Orbi is running in AP mode only.
If anybody has any suggestion how to solve this, that would be much appreciated!
In touch with NG support since 4 weeks to no avail so far.
Many thanks,
Mike
  • What Firmware version is currently loaded?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a full power OFF of the RBR and RBS been perfomed since last FW update?
    Try disabling AX mode on the RBR for 2.4Ghz...
  • FURRYe38's avatar
    • mikepade's avatar
      mikepade
      Tutor
      Hi there,
      thank you for your quick reply.
      Firmware is V4.6.3.16_2.0.51
      The modem is a Telstra Smart modem, we previously had an Orbi RBR50 plus 2 Satellites RBS50 working fine on the same setup.
      Home is a 2 story 300 sm single dwelling.
      When connected both Satellites show blue colour indicating they successfully synced and the connection between the router and satellite is good.
      Currently using channel 5 (2.4 GH) and 36 (5 GH).
      2 Wifi neighbours at least 15 m away.
      Yes full power off and hard reset has been performed multiple times.
      ok will now try disabling AX mode for 2.4 GH.
      • FURRYe38's avatar
        Is there a model # for the Telstra Smart modem?
