SJeWnelson
Jul 21, 2022Aspirant
RBK853- Devices often struggle to connect to network
Hi everyone! I've been an Orbi system owner for about half year now, and I've been having one persistent issue that i cannot resolve. My setup is RBK853 system + 2 separately bought RBS850s. All 4 sa...
Jul 21, 2022Guru - Experienced User
How many devices do you have connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only.
What is CTS set for currently? Try 2347?
SJeWnelson
Thanks for the response!
The modem unit is from my local Italian ISP- "TIM" called the TIM HUB but its an older model from 2016 (so maybe that could be an issue?). The connection we have is a DSL one with speed about 50 down/20 up. I think i should also mention that the modem doesn't have a bridge mode and I'm running RBR in router mode. But when i tried running Orbi in AP mode the issue persisted so I'm not sure if this setup is related to the issue. I switched back to router mode as i started having other problems related to wifi streaming when running in AP mode.
The home is a fairly big old concrete building, which is why i had to get 4 satellites, but they are all hardwired to the RBR850. The closest two satellites are about 8-9 meters from each other (≈28 feet) but they got 2 thick concrete walls between them so they barely overlap in coverage.
The channels are already at "1" for 2.4Ghz, and "40" for 5Ghz
20/40Mhz Coexistence is disabled, i dont think i have an option to specify 40Mhz only..
CTS is already at 2347
Preamble mode is in Auto (in case that matters)
Let me know if you have any other questions)
- FURRYe38Jul 21, 2022Guru - Experienced User
This modem hub have a built router and WiFi already?
By unchecking the box next to 20/40Mhz sets 40Mhz.
Concrete will be problematic for any wifi system.
- SJeWnelsonJul 21, 2022Aspirant
The Modem does have Routing and WIFI functionality, yes. I disabled wifi on it but, for whatever reason there is no an option to disable the router part.
Despite the concrete, RBR and 4 RBSs have a pretty much deadzone free coverage of the property. The annoying part is that devices would often take a few minutes to connect to network when they are like a meter away from a satellite. Feels like something goes wrong only during the handoff process between satellites when a device has to disconnect from one and connect to another. It does disconnect from a satellite in a room you leave but it takes ages to connect to a satellite located in a room you just entered. Hope that explanation makes sense..
I presume the RBS are wirelessly connected to the RBR?
