SJeWnelson
Jul 21, 2022Aspirant
RBK853- Devices often struggle to connect to network
Hi everyone! I've been an Orbi system owner for about half year now, and I've been having one persistent issue that i cannot resolve. My setup is RBK853 system + 2 separately bought RBS850s. All 4 sa...
SJeWnelson
Thanks for the response!
The modem unit is from my local Italian ISP- "TIM" called the TIM HUB but its an older model from 2016 (so maybe that could be an issue?). The connection we have is a DSL one with speed about 50 down/20 up. I think i should also mention that the modem doesn't have a bridge mode and I'm running RBR in router mode. But when i tried running Orbi in AP mode the issue persisted so I'm not sure if this setup is related to the issue. I switched back to router mode as i started having other problems related to wifi streaming when running in AP mode.
The home is a fairly big old concrete building, which is why i had to get 4 satellites, but they are all hardwired to the RBR850. The closest two satellites are about 8-9 meters from each other (≈28 feet) but they got 2 thick concrete walls between them so they barely overlap in coverage.
The channels are already at "1" for 2.4Ghz, and "40" for 5Ghz
20/40Mhz Coexistence is disabled, i dont think i have an option to specify 40Mhz only..
CTS is already at 2347
Preamble mode is in Auto (in case that matters)
Let me know if you have any other questions)
Jul 21, 2022Guru - Experienced User
This modem hub have a built router and WiFi already?
By unchecking the box next to 20/40Mhz sets 40Mhz.
Concrete will be problematic for any wifi system.
