darkinners
Aug 22, 2020Tutor
RBK853 3.2.16.6 firmware delete wifi password
Since I updated my RBK853 firmware to 3.2.16.6 If I change ANY setting via webbrowser. Orbi wifi will became "insecure" meaning you can connect to my Wifi SSID without password. To remedy this i...
Dd852
Aug 22, 2020Luminary
I had similar issues. I’ve reported to support but no reply yet. I solved by resetting router and satellites to factory, downgrading to 3.2.15.32 All fine now. It is possible that the factory reset was the trick and I could upgrade again but I have not dared to try - no reason to as the earlier firmware works well for me
darkinners
Aug 22, 2020Tutor
Hey man, I did couple of factory reset via GUI and it does not help but I tried to power down all my satellites and connect only the router and use a paper clip to do a factory reset via the hardware button. Then setup all over again and add the satellites one by one (both of them did a factory reset via hardware button as well)
It's working (for now) but I cannot change any settings now, if I change anything, it loopback to the initial issue I had and I have to do above steps all over again in order to solve it...
- FURRYe38Aug 22, 2020Guru - Experienced User
What browser are you using? Try Edge, IE11 or Opera. Ive not had any problems with v6 FW.
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
darkinners wrote:Hey man, I did couple of factory reset via GUI and it does not help but I tried to power down all my satellites and connect only the router and use a paper clip to do a factory reset via the hardware button. Then setup all over again and add the satellites one by one (both of them did a factory reset via hardware button as well)
- darkinnersAug 22, 2020Tutor
Thanks for the heads up, I will post over there.
I tried Chrome(PC/MAC), Edge(PC), Safari(Mac)
result is all the same, I even cleared browser cookie, cache and disable all extensions including adblock to try.
