Superpapu's avatar
Oct 19, 2021
Rbk853 satellite 2.4ghz
Hi, I have the rkb853.
I detect that all the devices are connected to the main router (2,4 and 5ghz) and none to the satellites even if the device is close to the satellite.
The satellites has 2.4ghz band?
what can I do to force the connections to the satellites in order to increase the signal? In both signals
thanks
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    is up to client devices to pick and choose where they connect too.
    You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    • Superpapu's avatar
      Superpapu
      Tutor
      Hi
      4.6.3.16_2.0.51
      the router is connected directly to the ont. the provider is Movistar (Spain). In general the wifi is perfect, it just the devices don't connect to the satellites
      is a 860 sq flat in 1 level.
      the distance is 150 sq with the first one and 300 sq with the second
      you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem
      • FURRYe38's avatar
        860 sq Feet or Meters?
        "you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem" No this is not what I said. >You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings < this is done thru the RBR web page using a web browser.
