Emmanuel666's avatar
Apr 23, 2021
RBK854 - System AX6000 et Répéteur Wifi Mesh d’extérieur
Bonjour,
je suis l'heureux propriétaire d'un système RBK854 (AX6000), mais je dois encore couvrir une partie jardin devant et derrière la maison. Sauriez vous m'indiquer quel modele d'exterieur serait compatible, car à premiere vue, je n'ai rien trouvé.
En vous remerciant par avance.
English below
Hi,
I'm the proud owner of an RBK854 (AX6000) system but i still have to cover part of the garden in front and behin the house.
Could you tell me wich outdoor model would be compatible, because at the first glance, i couldn't find anything.
Thank a lot.
Emmanuel
  • FURRYe38's avatar
    The only outdoor model that works with Orbi AX would be the RBS50Y, however you need to load the extender mode FW on the RBS50Y first.
      • FURRYe38's avatar
        They are only WiFi 5. There is no WiFi 6 outdoor extender currently.
