JJG1992
Mar 20, 2025Apprentice
RBK863 firmware update
I tryed updating to latest firmware soon as I did there was an instability with my download speeds went from 1Gb to about 5 to 10Mbps, I tryed resetting to factory setting and updating with the same result, I reverted to a previous firmware and everything is back to normal stable speeds just with a small minor problem with the 2.5 and 5Ghzs devises connecting to router what is at distance insted of to the satellite what is in the same room as the device. The orbi satellite updates with no issue devices will connect have sable wifi and Internet but soon as update the orbi router that's it Internet is on and off websites don't load keeps restarting, I am doing the update via ethernet and not wifi anyone els having this issue
Any progress on this?
- JJG1992Apprentice
7.2.6.31 works perfectly on the Orbi base Router and older provision of the firmware just not the current 7.2.7.15, the latest firmware works perfectly on the satellites but the Router has to be on older. I have noticed when doing a data capture when the Router on the latest firmware the DNS failes to certin websited on web browsers and apps on mobile devices , when I run a speed test to it goes up to 900MBps then slowly drops then fails and the base Router restarts, I have feeling the issue could be a bug in the firmware with the PPPoE settings. I'm busy testing th Vlan currently but that seems ok, next I am going to try DHCP and if i have stable Internet then I no its the PPPoE configuration in the new firmware .
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
