scan80269
May 15, 2025Guide
RBKE960 "Refused to Connect" after IP reservation changes
This is a report of a newly encountered issue with my Orbi RBKE963 (1 router + 2 satellites) running latest 7.2.7.15 firmware: After making IP reservation changes/additions and router rebooting, ...
May 15, 2025Guru - Experienced User
Not sure why the UI let you set the RBS at an IP address that is out side of your default IP address range, .100 to .199. IP address reservations need to be set WITH IN the IP address range, can not be out side. I use this same config and set my RBS at .149 and .150 for my IP address range of .100 to .150.
So set your RBS to .198 and .199.
