scan80269
May 15, 2025Guide
RBKE960 "Refused to Connect" after IP reservation changes
This is a report of a newly encountered issue with my Orbi RBKE963 (1 router + 2 satellites) running latest 7.2.7.15 firmware: After making IP reservation changes/additions and router rebooting, ...
RickQ
May 22, 2025Tutor
Going through this thread, I believe that my issue is exactly what you have experienced. I went through a file I created that had my IP address listed and realized that I have a single device with a static IP address that falls within my DHCP range.
But reading through your message above, I'm a little confused. Did your RBS's have static IP addresses originally of 192.168.0.2 and 192.168.0.3 or were they dynamic?
The reason I ask is because you use the term 'IP address reservations'. I've always associated that term with static IP addresses.
You stated above that you changed your DHCP address pool range to be 192.168.0.2 to 192.168.0.199 so that your satellites are included. But if your satellites have static IP addresses, that would be an incorrect configuration.
So, are the satellite IP's static or dynamic?
Thanks in advance for your response.
scan80269
May 22, 2025Guide
The two Orbi satellites were given 192.168.0.2 and 192.168.0.3 addresses via the Address Reservation feature of the Orbi router. Those satellites were never manually assigned static IP addresses as I actually don't know how to do so. The satellites' IP addresses are thus effectively dynamic, though via Address Reservation those addresses never change.
I find that Address Reservation feature of Orbi pretty much eliminates the need to set static IP addresses for any WiFi client, so they can all be left using DHCP by default. I have a PC acting as VPN server and it needs some port forwarding to properly support outside-in access to my home network. Using Address Reservation ensures this device has an unchanging IP address. Building up a set of address reservations in the Orbi router is also way easier than manually setting up multiple clients with static IP addresses.
Hope this helps!
