scan80269
May 15, 2025Guide
RBKE960 "Refused to Connect" after IP reservation changes
This is a report of a newly encountered issue with my Orbi RBKE963 (1 router + 2 satellites) running latest 7.2.7.15 firmware: After making IP reservation changes/additions and router rebooting, ...
scan80269
Aug 19, 2025Guide
OK, I undid the "Solved" state of this issue, as it continues to occur with my RBRE960 router, despite having made the DHCP IP range adjustment along with changing my Pi-hole device to use a static IP address. Making changes/additions to the DHCP reservation list followed by a router reboot is what typically triggers this issue of the router refusing to connect to browser for admin. There's also been a few times when the router would refuse to connect sometime after working normally, without me making any settings changes.
As indicated previously, once the router "refuses to connect", the only recovery method is to hard reset the router, go through new device setup, then restoring settings from a backup.
I'm more convinced than ever that this is a bug introduced with 7.2.7.15 firmware.
- FURRYe38Aug 19, 2025Guru - Experienced User
So if you feel all was good on prior version of FW, lets go back to that and see how it goes...
I saw no issues with my 963 system on v.15, though I don't have IPv6 from ISP nor PiHole services running.
