Talon38's avatar
Talon38
Tutor
Jan 20, 2022
RBKE963B - Help picking cable modem for Spectrum
I purchased a New Orbi 6E kit and have it installed.  I would like to replace the Spectrum CM with a new model that will match the Orbi system as Spectrum increases its speeds from 1 G to 2-5G to 10G.  What CM would you buy and would you use link aggregation or a 2.5G modem?  Thanks for your help!  Mike
  • the fastest modem right now is the CM2000 which has a 2.5g port.
    I haven't seen any 5g or 10g ports on consumer modems (and the ISP's don't support that on docsis 3.1)
  • CrimpOn's avatar
    CrimpOn
    one port rather than port aggregation.
    If you get telephone service from Spectrum, the modem must include that feature.
    • Talon38's avatar
      Talon38
      Tutor
      Thanks!  We d/c'd our home phones due to quack callers (40+ per day) and now use cell phones and RoboKiller (great software BTW), so only need the modem.
      Cheers!
      • plemans's avatar
