bouchi's avatar
bouchi
Tutor
Jul 09, 2022
RBKE963B & Outdoor Satellite
Hello,
I'm thinking about buying a new Orbi WiFi 6E RBKE963B pack and and want to know if Orbi outdoor satellites are fully compatible in a mesh network configuration ?
I'm not able to find outdoor satellites WiFi 6E compatible, only RBS50Y or RBS50Yv2 but they only seems WiFi 5 compatible.
So to summarize :
1. If I bought RBKE963B pack + RBS50Yv2 satellite, will I be able to get a full mesh network running with WiFi 6E inside the home and WiFi 5 outside with same SSID and all transparent for my devices ?
2. Is it in the loop to have outdoor satellites WiFi 6E compatible ?
Thank you in advance for your help.
Bouchi
  • bouchi wrote:
    Hello,
    thank you very much for your fast and complete answer.
    As I'm not yet an Orbi user, could you please tell me what the Orbi mode provide more than a Mesh extender ?---Orbi mode basically the router has more control between router/satellites to help with daisy chaining/star topology. It also seems to be a little smoother on smart roaming (subjective from me) even though its the device itself that decides when it roams between router/satellites.
    If you can advise me based on your experience, what will you do ?
    1. Buy RBKE963B + RBS50Y (or RBS50Yv2) and running in the mesh extender configuration ?
    2. Buy RBKE963B only and wait for a potential WiFi 6E Orbi outdoor ?
    3. Buy indoor and outdoor full compatible WiFi 5 Orbi system (AC3000, Orbi Pro WiFi 5 (SRK60B03)) until WiFi 6E will be generalized or replaced by WiFi 7 ?
    Thank you
    Bouchi
    Are you needing the boost in speed/coverage? If it was me, I'd try the RBKE system with an outdoor extender. But I'd buy from somewhere with a generous return policy. that way if it doesn't provide the coverage/needs that you expect from the price, then you could return it and go with a standard AC system. I've used both the RBK53 and have the RBKE963. And I have a RBK50Y that I used with my RBK53. Do I notice much difference from going from an AC system to an AX system? Not really unless I'm speedtesting.
  • plemans's avatar
    Would it connect to your system in orbi mode? No.
    But you can connect it in extender mode and run it with the same ssid since its a mesh extender.
    would it be as efficient in its roaming performance? Unknown as I haven't tried it.
    Netgear doesn't tell us updates about upcoming products
    • bouchi's avatar
      bouchi
      Tutor
      Hello,
      Thank you
      Bouchi
      • plemans's avatar
        bouchi wrote:
        Hello,
        Thank you
        Bouchi
