henry0111
May 10, 2022Aspirant
RBR 750 - router showing offline + ios devices cannot load certain websites
Hello,
Since last week, I noticed that my iOS devices cannot load certain websites like Google, Youtube, App Store, Gmail.
This happened only when my iOS devices connected to Wifi. When I switched back to the cellular network, those website can be loaded without issue. I confirm that it must be the Wifi connection caused the issue. Is there anything I can adjust to fix it?
For your reference, I have done factory reset, updated to the latest firmware for my RBR750 + RBS750 to v.4.6.8.2_2.1.9 for multiple times, the issue still persist. And after the firmware update, the router will constantly showing disconnect/ offline.
I’m frustrated and helpless, can any expert help me?
- henry0111Aspirant
Be sure to review this as well:
- henry0111Aspirant
What mode is your modem working in? Router or Bridge mode? This model # reports it having a router and wifi built in.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
