RandyL2
May 28, 2022Follower
RBR 750 connectivity
Perhaps this has been going on ever since I installed my Orbi system about a year ago, but I just noticed that my computer connects to the main router, which is one floor below and about 20' away instead of to the nearest satellite which is in the same room as the computer and about 5' away. The signal strength of the connection is 3 out of 4 bars and the system seems to operate OK, but I'm curious why the connection would be to the router, which is further from the computer.
The firmware is up-to-date (v4.6.8.2).
Any thoughts about why this happens?
Thanks.
1 Reply
Whether it connects to the satellite or to the router is based on its own roaming protocols.
If you're on windows, you can go in and change its roaming aggressiveness.
