lisakc's avatar
lisakc
Tutor
Apr 03, 2022
RBR 750 Daisy Chain
I was just told that my RBR 750 and ALL Orbi wifi 6 mesh systems do NOT support a Daisy chain topology. There is no way for me to enable this feature when logging into the router. Does anyone have any current info on this topic? I have updated to current firmware V4.6.5.14_2.0.54, do NOT have the armor security. Router on second story, satellites on first story.
Thank you!
  • plemans's avatar
    Its just not something that's user controlled. Its auto-negotiated by the orbi based on whats better performing
    • lisakc's avatar
      lisakc
      Tutor
      I don't think its making a very good choice, so no way to configure it then?
      • plemans's avatar
        Its not user changeable.
        But you can try changing distances between router/satellites. That can sometimes impact how it negotiates it.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Thank you!
