fdelmo10
May 07, 2025Tutor
rbr 750 firm V7.2.7.15_5.1.16
MY wifi is not strong on firesticks and phone. on my wired pc is getting 325 plus reading. I have Enable AX - This WiFi mode will enable AX features ,What other setting should I try . My wifi is rea...
fdelmo10
May 07, 2025Tutor
The speed is 594.92 mbps on my pc thru the router app My phone is a galaxy 22 speed 52.85 mbps I have 3 additional satellites in my house 4200 sq feet. I have a spectrum modem DOCSIS 3.1 Modem. My wifi channels 7 and 48 I have 33 devices connected 12 at 2.4g, 17 at 5g , 4 are wired
May 07, 2025Guru - Experienced User
Can you try setting channel 11 and 48 on the RBR.
Then turn OFF two RBS for now leaving the RBR and just 1 RBS deployed. Later lets turn on a 2nd RBS after checking this.
Be sure that your disabling then re-enabled WiFi on wireless speed testing devices when you are near the RBR to ensure they are connecting at the RBR and not a remote RBS. Be around 6-10feet away from the RBR.
- fdelmo10May 07, 2025Tutor
All done the devices reconnected to the rbr750 Speed was 82 for the phone 18 for the firestick the wired pc speed 573
- fdelmo10May 10, 2025Tutor
does it matter my wireless setting for
5ghz
Up to 1201 Mbps
Do you have other suggestions , i can try
- FURRYe38May 10, 2025Guru - Experienced User
