fdelmo10
May 07, 2025Tutor
rbr 750 firm V7.2.7.15_5.1.16
MY wifi is not strong on firesticks and phone. on my wired pc is getting 325 plus reading. I have Enable AX - This WiFi mode will enable AX features ,What other setting should I try . My wifi is rea...
May 07, 2025Guru - Experienced User
Can you try setting channel 11 and 48 on the RBR.
Then turn OFF two RBS for now leaving the RBR and just 1 RBS deployed. Later lets turn on a 2nd RBS after checking this.
Be sure that your disabling then re-enabled WiFi on wireless speed testing devices when you are near the RBR to ensure they are connecting at the RBR and not a remote RBS. Be around 6-10feet away from the RBR.
