wheatt
Sep 19, 2022Aspirant
RBR 750 intermittently crashes with high load on ethernet
I've tried repeatedly searching and see this problem mentioned, but I've yet to see a solution. I've got an RBR750 (latest firmware, +2 wired satellites) connected to a CM1100 cable modem with gi...
ekhalil
Sep 19, 2022Master
I think this is the same intermittent issue that is currently seen with wired satellites. Please try the workaround mentioned in the following posts:
- https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Orbi-RBR350-in-AP-mode-not-always-getting-DHCP-IP-when-roaming/m-p/2257440/highlight/true#M38241
- https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBS850-wired-backhaul-poor-connectivity/m-p/2256603#M38109
- wheattSep 20, 2022Aspirant
Thanks for the suggestion. I don't think this is my issue though because my computer is connected by direct wire connection to the router?
