sajid4077
Jul 28, 2022Tutor
Rbr 750 requires daily reboot
Hi, I have the rbr750 orbi system with 2 satellites. The current firmware is 4.6.8.2_2.1.9. My download speed is supposed to be 1000mbps, but speedtests around 600-900 at normal times. But, everyd...
- Aug 02, 2022
Glad to hear it was a sketchy connector!
You might mark your solution as solved so people know what fixed the issue 🙂
Let us know if you have further issues
Jul 29, 2022Guru - Experienced User
Try testing using the speedtest app/browser on a hardwired in device.
The app doesn't always pick the best server so its worth seeing if its something related to the router itself or the speedtest server its choosing.
