sajid4077
Jul 28, 2022Tutor
Rbr 750 requires daily reboot
Hi, I have the rbr750 orbi system with 2 satellites. The current firmware is 4.6.8.2_2.1.9. My download speed is supposed to be 1000mbps, but speedtests around 600-900 at normal times. But, everyd...
- Aug 02, 2022
Glad to hear it was a sketchy connector!
You might mark your solution as solved so people know what fixed the issue đ
Let us know if you have further issues
Jul 29, 2022Guru - Experienced User
Try testing using the speedtest app/browser on a hardwired in device.
The app doesn't always pick the best server so its worth seeing if its something related to the router itself or the speedtest server its choosing.
sajid4077
Jul 31, 2022Tutor
Results are the same using speed test. I notice the speeds drop on hardwired devices and that's when I test the speed and see the bad results. Reboot generally fixes it, but recently I've had to hard power recycle the router to get the speeds to restore âčïž
