sajid4077
Jul 28, 2022Tutor
Rbr 750 requires daily reboot
Hi, I have the rbr750 orbi system with 2 satellites. The current firmware is 4.6.8.2_2.1.9. My download speed is supposed to be 1000mbps, but speedtests around 600-900 at normal times. But, everyd...
- Aug 02, 2022
Glad to hear it was a sketchy connector!
You might mark your solution as solved so people know what fixed the issue 🙂
Let us know if you have further issues
Aug 01, 2022Guru - Experienced User
when its dropping in speed, whats showing in the wan port statistics page.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
sajid4077
Aug 01, 2022Tutor
See Attached.
