sajid4077
Jul 28, 2022Tutor
Rbr 750 requires daily reboot
Hi, I have the rbr750 orbi system with 2 satellites. The current firmware is 4.6.8.2_2.1.9. My download speed is supposed to be 1000mbps, but speedtests around 600-900 at normal times. But, everyd...
- Aug 02, 2022
Glad to hear it was a sketchy connector!
You might mark your solution as solved so people know what fixed the issue 🙂
Let us know if you have further issues
sajid4077
Aug 01, 2022Tutor
See Attached.
Aug 01, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. If your ISP Modem or ONT supports 2.5Gb on there WAN port, CAT6A STP cable would be recommended.
- sajid4077Aug 01, 2022TutorI don't have a cable modem. It's directly connected to the line outside my house. The outside line is connected with Cat7 which feeds into the Orbi Router. I will ask the cable company to redo the pinout on the external connection to see maybe that fixes the problem 🤷🏽‍♂️
I'm really out of ideas- FURRYe38Aug 01, 2022Guru - Experienced User
I would ask the ISP if there is a interface unit out side or ONT. There has to be something that is converting the ISP data media to ethernet media.
Also give this a try:
Also enable SIP ALG on your RBR as well.
