sajid4077
Jul 28, 2022Tutor
Rbr 750 requires daily reboot
Hi, I have the rbr750 orbi system with 2 satellites. The current firmware is 4.6.8.2_2.1.9. My download speed is supposed to be 1000mbps, but speedtests around 600-900 at normal times. But, everyd...
- Aug 02, 2022
Glad to hear it was a sketchy connector!
You might mark your solution as solved so people know what fixed the issue 🙂
Let us know if you have further issues
sajid4077
Aug 02, 2022Tutor
So it turns out, the tech was actually really smart.
Since my house is wired for Cat7, when the internet was started back in the day, that tech didn't have a way to pin a cat7 cable, so he had fenagled a cat7 to cat5 connection which was shady at best. This was behind a "locked" section which I couldn't see, so I had no idea it was so badly done.
This new tech, ripped it all out and wired it correctly. It's still a cat7 to Cat5 connection, which adds a point of failure. These guys don't carry cat7 pins or crimper tool. I've ordered those so I can just make that connection directly into the ONT outside instead of having that connection.
But for now, it all works and speeds are back up.
Aug 02, 2022Guru - Experienced User
