chris38
Feb 03, 2026Aspirant
RBR 760 satellite
Hi i have a orbi rbr760 with 2 satellite, i want to add an other satellite but i don't found the same reference. is there an other version is compatible with RBR760 ? Thanks
Feb 04, 2026Guru - Experienced User
How big is your home?
There's been a few times, we've actually seen people have to many satellites and it causes issues with roaming and stability.
A router and 2 satellites should cover a fairly large home (provided it isn't made from brick/concrete/plaster lathe)
plemans wrote:A router and 2 satellites should cover a fairly large home (provided it isn't made from brick/concrete/plaster lathe)
Agreed.
chris38: Before you purchase, I suggest checking the signal strength around your home using a wifi analyzer on your phone. If you are seeing RSSI values of -70 dbm or better, then you should have good whole-house coverage.
If you see an area where you are getting -30 dbm or better from two or more mesh elements, then you likely have some interference. If that is your situation, you could repositioning the satellites. Or try one of them off.
- chris38Feb 04, 2026Aspirant
my house is with 3 level, the modem is in the middle, i don't have issue with the wifi inside
but i have camera outside and i don't receive the wifi on 1 side of the house outside
is why i want to put an other satellite for the outside
did you have a good app for ios for analyse the wifi ?
Thanks
- plemansFeb 04, 2026Guru - Experienced User
Whats the exterior of the house made of? Things like metal siding, concrete board, brick, etc are all great at blocking wifi.
If you have those, its then trying to find a way to get the signal outdoors.
yes it is concrete board with steel inside, i can put an other sattelite closed to a windows so the wifi can go outside
- StephenBFeb 04, 2026Guru - Experienced User
You can use Apple's AirPort utility. Although it is intended to manager AirPort base stations, it has a wifi scanning mode that will give you the RSSI of all the networks it sees.
Not pretty, but it does work ok. It's the only free one I know of.
- FURRYe38Feb 05, 2026Guru - Experienced User
Only possible way to get some signal outside would be to get another RBS760, if you can find another, or find a simple low bugdet router that has AP mode features. Find you a outdoor rated electronics box, plastic or composite that doesn't block wifi signals. Run a ethernet cable from the orbi RBR out to this outside location where the outdoor electronics box is and put in this box the RBS or AP. If an AP, just configure it for far appart channels from what the Orbi uses. Have the camera connect to this AP.
There is some outdoor rated electronic boxes on amazon. Seen others post about this in the past. Good alternative since NG doesn't produce a outdoor rated RBS anymore from the RBS50Y.
Another item you could check into is NGs WAX608Y or 610Y. These are out door rated APs.
- StephenBFeb 05, 2026Guru - Experienced User
I'd first try moving one of the satellites to the nearby window, and see if that gets enough signal to the camera. Then explore other solutions.
The WAX608Y is pretty expensive, especially if you only want to connect to one camera. The 610Y is about the same price as an RBS760. But it does require power-over-ethernet (PoE).
chris38: If you are prepared to run power outside, you might instead replace the camera with a PoE model. You could then use a power injector indoors to power it (or get an PoE switch). This might be cheaper than adding in an outdoor AP, and you often get better performance from a PoE camera.
