chris38
Feb 03, 2026Aspirant
RBR 760 satellite
Hi i have a orbi rbr760 with 2 satellite, i want to add an other satellite but i don't found the same reference. is there an other version is compatible with RBR760 ? Thanks
chris38
Feb 04, 2026Aspirant
my house is with 3 level, the modem is in the middle, i don't have issue with the wifi inside
but i have camera outside and i don't receive the wifi on 1 side of the house outside
is why i want to put an other satellite for the outside
did you have a good app for ios for analyse the wifi ?
Thanks
Feb 04, 2026Guru - Experienced User
Whats the exterior of the house made of? Things like metal siding, concrete board, brick, etc are all great at blocking wifi.
If you have those, its then trying to find a way to get the signal outdoors.
- chris38Feb 04, 2026Aspirant
yes it is concrete board with steel inside, i can put an other sattelite closed to a windows so the wifi can go outside
- plemansFeb 04, 2026Guru - Experienced User
I'd test it with one of your current ones. Just stick it in a window and if everything works, might not need another satellite. That combination should cover a substantial sized home
