chris38
Feb 03, 2026Aspirant
RBR 760 satellite
Hi i have a orbi rbr760 with 2 satellite, i want to add an other satellite but i don't found the same reference. is there an other version is compatible with RBR760 ? Thanks
chris38
Feb 04, 2026Aspirant
yes it is concrete board with steel inside, i can put an other sattelite closed to a windows so the wifi can go outside
Feb 04, 2026Guru - Experienced User
I'd test it with one of your current ones. Just stick it in a window and if everything works, might not need another satellite. That combination should cover a substantial sized home
