gerardw's avatar
gerardw
Initiate
Sep 04, 2021
RBR 850 device connectivity
I briefly tried another router, but was unhappy and went back to my Orbi RBR 850.
Some devices (Sonos sound system and security camera system) no longer connect to my Orbi router. They don't show up on the list of devices appearing on the iOS app. The other 12 devices work fine. Any suggestions would be appreciated
  • michaelkenward's avatar
    michaelkenward
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    Those things are different from the standard Netgear routers covered in this section.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
    Good Luck.
  • FURRYe38's avatar
    Any progress on this?
    • gerardw's avatar
      gerardw
      Initiate
      Thanks for asking. The answer is yes and no. I had a technician come and look at the camera system and he was able to connect it to the wifi. The sonos network magically reappeared in the list of devices, then disappeared again after a few days. I am now using a wired ethernet connection between sonos and orbi and that at least seems to work.
      • FURRYe38's avatar
        Sonos has there own wifi so this could be one issue. I believe historically users should use ethernet connection with Sonos.
        Also check out CTS Under Advanced Tab/Advanced Settings/Wireless Settings and set to 2347 if you seem to have other wifi issues.
