dsingerUNC's avatar
dsingerUNC
RBR 850 firmware update 4.6.3.16
I have 1 RBR850 with 4 RBS850s that are hard wired to the RBR850. The app prompted me to upgrade to 4.6.3.16 today, which I did. However, only the RBR850 and 2 of the 4 RBS850s upgraded. The other two are still on the prior firmware version and now say Backhaul Status is "Out of Sync". I have tried rebooting, but it appears your app did not update the satellites first as it is supposed to. I tried to manually update the remaining 2 RBS850s that are on the old firmware (4.6.3.9), but I can no longer access them (the window just comes up blank, likely because they are Out of Sync). I have hit a brick wall and need help!
  • FURRYe38's avatar
    Can you access the RBS web page using there IP addresses seen on the RBRs web page?
    • dsingerUNC's avatar
      dsingerUNC
      I cannot. It just is blank - same as when I try to click the manual firmware update on each one.
      • FURRYe38's avatar
        Downgrade the RBR back to v9. Then see if you can connect to the RBS. If so, manually send the v16 update. After that re-udpate the RBR lastly.
