skeelo
Nov 22, 2022Luminary
RBR and Sats Disconnect Monthly
RBR 850 and 3 RBS850
V4.6.9.11_2.3.5
Century Link ISP, 1G up and down
RBR and sats disconnect monthly, can almost set my watch by it. This has been an issue going back to 2020 and FW: V3.2.16.6_1.4.4. Has to be related to some internal lease timer or something given monthly consistency. The only way to get everything back up is to unplug all (ISP, RBR, RBS) then plug back in. Any ideas?
Rant: cannot believe I am over $1k into this system and continuing to have these issues. Internet connectivity has been table stakes since forever. /Rant
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What channels are you using? Auto? Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Do you have Armor, SPC, or Traffic Meter enabled at any point or currently?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings- skeeloLuminary
- Latest firmware.
- Don't know the modem/ ONT model number - it's not the issue. I get no disconnects when connecting to my ISPs router (wired or wireless), however, coverage is horrible.
- All new cat 6 was installed throughout when the house was built 2.5 years ago.
- 6,500 sq ft and at least 30 ft between RBS and RBSs.
- Already on 01 and 40 for 2.4 and 5g, respectively.
- No Armor, SPC, or Traffic enabled currently. Turned off a year ago when trying to originally fix this disconnect issue.
Not setting the device up from scratch again, too much of a hassle and having done this in the past I know it does not fix the issue. This has been an ongoing since the summer of 2020. Every month, around the same time of the month, the system loses connectivity (wired and wireless devices) while connectivity at the modem remains unchanged.
I am not the first to report this issue and I have jumped through the hoops to try and fix. IMO this is an unaddressed software issue dating back to V3.2.16.6_1.4.4.
I've not seen anyone report about this recently in past year or so. I believe others have seen well over 30 days as well. I believe if other are seeing this they would have posted about it. I check Reddit as well. Looking at your post history you didn't mention it either back then.
I see you have a Zyxel C3000Z if this hasn't changed?
You might change the power settings on the RBR to 50% and see if this helps any. Having 3 RBS maybe too much for your size of home. I can run one RBS in 5K sq ft home and works well. If I have two online I reduce the power to 50%.
You might trying running two RBS at 50% power and see if this changed the behavior at 30 days.
You may have just have had a faulty unit from the beginning as well. You can reach out to a forum moderator and see what your options are.
Is it correct to assume that the RBR850 is in the (default) router mode? (not in Access Point mode)
Restarting only the RBR850 does not restore service? i.e the ISP router must be restarted as well?
Is IPv6 enabled on the RBR850?
The question about address reservations is interesting. I cannot find anything in the Zyxel C3000Z user manual that specifies the length of the DHCP lease that it assigned to attached devices (i.e. the RBR850):
(The default DHCP lease my RBR50 router assigns to devices is 86,400 seconds (1 day).
The length of the IPv4 lease assigned by the Zyxel to the RBR850 should appear in the router Advanced Tab, in the Internet Box in the Blue Box "Connection Status". For example, Spectrum assigns my RBR50 a DHCP lease of 86,400 seconds (1 Day, 0 hours, 0 minutes) I have verified that (as expected) my router attempts to renew the DHCP lease when 50% of the time remains, i.e. at 12 hours, and that Spectrum consistently renews the DHCP lease as expected.
I also learned that Spectrum assigns an IPv6 lease to my router of 1 week. i.e., 604,800 seconds. and the router renews this lease when 50% of the lease time remains. I know of no way for the user to display the IPv6 lease time. I discovered it by snooping on the connection between modem and router.
- skeeloLuminary
Late reply, apologies.
Was running great for over a month using just the router. Plugged in the first of three satellites two weeks ago to test and started having issues today. Answers below in order:
- Yes, default router mode.
- Have never tried restarting only the RBR, have always restarted both. With that, have always had wired connection to ISP device despite no connectivity from the router. Was previously the first thing I would check/ troubleshoot before restarting all.
- Yes, IPV6 is enabled at ISP and router level.
Perhaps it would be useful to describe the "issues" in more detail.
- The router says, "no internet"?
- Devices lose connection to the router?
- Devices remain connected to router but claim, "no internet"?
Meanwhile, the ISP router continues on?
I see that new firmware was released for the 850 product on 12/1, V4.6.14.3. Has the system been updated to that version?
