Theobuck
Aug 03, 2023Apprentice
RBR placement
Our apartment has RJ45 ports in 4 rooms, but they terminate in the Master bedroom closet, where the Optical Network Terminal is located. I wish the design was diffrent but it what I have to work with unfourthently.
Currently, I have it set up where one of the ports is active and connected to the router in a small office area, and the other three ports are not active. The performance is okay, but I would like to be able to use the other ports for backhauling and for direct conntions.
My question is; Is it wise to put an Orbi RBR 750 in a mostly enclosed space and backhaul the two satellites using the RJ45 ports?
Probably.
Distance between a wifi router and other devices should be 3-6 feet.
Maybe not idea however can work if you can connect the remote lan ports in these rooms to the back of the RBR:
