AndreaPav's avatar
AndreaPav
RBR350 e IPoE per Sky WiFi
Buona sera a tutti,
ho appena installato FTTH con sky wifi e avevo già una rete con degli ORBI Wifi 6.
Volevo utilizzarli direttamente senza router collegando direttamente l'ONT ma non sono riuscito a configurarlo. Nello specifico il problema sembra essere il protocollo IPoE, che non trovo sul router.
Che devo fare?
Grazie
Andrea
  • Ciao to all!
    I've finally found the problem. My ISP use IPv6 and I had to manually enable it.
    The provider is Sky, and the config is just DHCP + IPv6 + enable VLAN/Bridge with ID 101
    Have a good day
    Andrea
  • Hi!
    I have installed a new FTTH network with Sky WiFi.
    Now I have a problem, I would like to use my Orbi 6 directly connected to the ONT but i have to use IPoE protocol, and I cannot find it (only PPPoE and others).
    Can someone help me? It is supported?
    Thank you in advance.
    Andrea
    • FURRYe38's avatar
      Please contact the ISP for help and information regarding this. They should be able to help you on this. Ask the about there hardware and configuration requirements.
      Good Luck.
      • AndreaPav's avatar
        AndreaPav
        they told me that i have to find IPoE (and not PPPoE), but i cannot find it.
        Is it supported?
        thank you
