Miniatuur
May 11, 2025Aspirant
RBR350 lost connection to satellite
Hi, my RBR350 router (running on latest firmware) worked for 2 years with no problem and now for several months (from feb) I lose my connection to the satellite, and then also no WiFi. I updated the firmware, did an check of my internet connection with my provider but everything looks good. I really don’t know what to do anymore. I don’t use the system now, but need the improved WiFi network. The satellites are connected wireless to the router. Who can help me?
Did you update the RBS first? RBS FW need updating first before the RBR is updated...
- MiniatuurAspirant
I thought so, but started over just to be sure. I do now have problems getting into satellite for the update! Via lan it doesn't work. I do get the question for login but after that the screen remains blank.
