Miniatuur's avatar
Miniatuur
RBR350 lost connection to satellite
Hi, my RBR350 router (running on latest firmware) worked for 2 years with no problem and now for several months (from feb) I lose my connection to the satellite, and then also no WiFi. I updated the firmware, did an check of my internet connection with my provider but everything looks good. I really don’t know what to do anymore. I don’t use the system now, but need the improved WiFi network. The satellites are connected wireless to the router. Who can help me?
  • I thought so, but started over just to be sure. I do now have problems getting into satellite for the update! Via lan it doesn't work. I do get the question for login but after that the screen remains blank.
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello Miniatuur,
      Welcome to the NETGEAR Community!
      Which firmware did you install on your Orbi router?
      Best,
      Kevin
      Community Team
  • FURRYe38's avatar
    Did you update the RBS first? RBS FW need updating first before the RBR is updated...
