taj's avatar
taj
Follower
Nov 08, 2022
RBR350
Hi , I have RBR350 and 2 satellites are hard wired. And RBR350 is set up as access point. When there is Power Outage, one of the satellites do not get connected. At one point there was Magenta light at the satellite. On the Orbi App, the satellite is showing as "OFFLINE". I could sync the router and satellites again, but how can i avoid this in the event of power outage ? thanks
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    All RBS using same version of FW as the RBR?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello taj,
    Welcome to the NETGEAR Community!
    I understand that during power outages you have to re-sync one of your satellites to your RBR350. To prevent the need to re-sync your satellite, please turn on one satellite at a time after the power returns to your facility.
    Best,
    Kevin
    Community Team
