Wizzard370
May 10, 2023Tutor
RBR353 and ethernet cable connection
I have RBR353 mesh - Base (Router) plus 2 satallites. The Base has an ethernet connection to a 16 port switch (devices like PC, scanner, printer etc. feed into this switch.)
I want to connect one of the satalites to the base unit using an ethernet cat 6 cable. Should I connect it to the Switch or directly to one of Base Unit the ethernet ports please?
You can do either. Either would work fine.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
1 Reply
