jwf2's avatar
jwf2
Follower
Nov 22, 2021
RBR750 – can’t connect can't connect to primary network, only to guest
All of a sudden my Orbi (NETGEAR AX4200 Orbi WiFi 6
High-Performance Whole Home Mesh(RBR750) wouldn't connect to the primary network.  It will connect to the guest network only.  Please help and I have limited knowledge on how to fix this debacle.
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you
  • FURRYe38's avatar
    What devices are you trying to connect to the Orbi system?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
