heady006
Feb 04, 2026Aspirant
RBR750 - FTTP installed
Team, I have just had FTTP installed. My previous connection with TPG ran through an older TPG modem then into my Orbi system. With my new connection I am trying to connect my Orbi directly to the fi...
Feb 05, 2026Guru - Experienced User
Ask the ISP if you should be using DHCP or PPPoE.
Disable IPv6 on the RBR.
Is the phone the only device not getting internet?
Has a power off for 1 minute then back ON with the ISP modem/ONT and router and satellite(s) been performed?
If your ISP Modem or ONT already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-pointand https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
