jdmcr
Feb 11, 2023Aspirant
RBR750 - Minecraft "Unable to Connect to World" on LAN
Hi Purchased a new RBR750. Kids can connect to external Minecraft servers and worlds, but can no longer connect to worlds that they create and play together on the LAN. We can see the world, but g...
- Feb 12, 2023
I don't use or know Minecraft, but guesses:
* On iPad and iPhone devices, click into the wifi network and switch off "Private Wi-Fi Address". This is set per network so might be different from your previous router's network.
* Found this other iPad Privacy Minecraft setting - Navigate to the "Privacy" folder then the "Local Network" option, under there set "Minecraft" to "on": https://answers.microsoft.com/en-us/xbox/forum/all/re-minecraft-pocket-edition-for-ipad/340467fe-00a1-4e17-8eaf-aa6e6fd0946f
Feb 11, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
