Chuckg7
Jun 30, 2026Aspirant
RBR750 / RBS audio server issue
RBR750 and 3x RBS750s AS of about a month ago my apple airport express units will quit streaming audio to my whole house system after a couple songs... Yes the express units are older but I have...
Chuckg7
Changed the wireless from auto to channel 6 on the 2.4 side
IPv6 is disabled, no Armor
Not sure what SPC is or where to check that?
Jul 01, 2026Guru - Experienced User
Chuckg7 wrote:Not sure what SPC is?
parental controls
Also, are you using MAC access controls (which block unknown devices from connecting). If you do, try disabling that, and see if it makes any difference.
