dbrb2
Apr 02, 2023Apprentice
RBR750 and RBS750 not seeing each other with wired backhaul
I have an RBR750 set up in AP mode
I also have an RBS750
Both are running V4.6.14.3
Both units are connected to a switch via their LAN ports (I am not using the RBR as a router)
Both units are reachable, and both are providing wifi access succesfully to various devices.
However, the RBR750 shows "0 satellites connected" and likewise the RBS750 shows that it has no connection to the router
From what I had read, I though these two units should be able to see each other using a wired backhaul...?
What is the Mfr and model# of the host router the NG router is connected too?
How is the RBR connected to the host router? WAN port?
Whats the brand and model# of the LAN switch being used?
What CAT# LAN cable is being used? CAT6 is recommended.
Try the RBS directly connected to the back of the RBR with out the switch?
- dbrb2Apprentice
RBR750
Firmware Version V4.6.14.3_2.3.12
GUI Language Version V3.0.1.54_2.1.30.3How is the RBR connected to the host router? WAN port?
RBR is connected to the main gigE switch using a cat6 cable
RBR is set up in AP mode
The internet router is also connected to this switch
The WAN port on the RBR is not used
It's an unmanaged 8 port gigE switch from TPLink - TL-SG108S
How do the devices discover each other?
CAT6
Unfortunately that would be a problem with the available cabling. I might be able to work something out temporarily though. However, at that point they would be so close that I presumably wouldn't know if the backhaul was wired or wireless...?
Both devices are visible on the network - and both are providing wifi access to devices - but if they are not seeing each other, that presumably means both are acting as standalone access points....which may or may not have any real-world effect in terms of device handover etc...?
RBR750
GUI Language Version V3.0.1.54_2.1.30.3What is the other routers brand name and model# that the RBR750 is connected too?
The WAN port on the RBR is not used <The WAN port on the RBR while in AP mode HAS to be used for proper operation of the RBR AND RBS.
CAT6
Something to try as a quick test to see if the RBS sync over ethernet to the back of the RBR and they show properly when ethernet connected on the RBRs web page. Wired status should appear for each RBS after they successfully sync over ethernet.
