OahuOrbi's avatar
OahuOrbi
RBR750 Done with this equipment
When I lose power which happens often here in North Shore Hawaii Oahu when the router comes back online it slowly connects but my samsung's top of the line phone will not connect to it. Then it won't connect to the satellite either, meaning the router. I have restarted the router multiple times without luck and have to leave it to sit for at least 12 hours until for some reason, the Wi-Fi will connect to my phone again and other items including the satellite this is highly frustrating to a piece of equipment as expensive as this was for it to work inconsistently. Has anyone else had these problems? I'm ready to switch over to the EERO product.
  • What Firmware version is currently loaded?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Armor, Smart Parental Controls or Circle, Traffic Meter.
